Should I use internal engine cleaner?
Old Jul 17, 2012 | 08:49 PM
buttton's Avatar
Hello,
I am in need of some opinions from those of you with more experience than I, when it comes to internal engine cleaning without tearing down the motor itself.
I just got a 69 Satellite (318) that was sitting for 12 years, tuned it up a bit and it seems to run really good, except for a slight pinging in the motor. I dont know if it is valves or bearings or what. If I really step on it the sound goes away.
My question is should I use a seafoam or some other internal cleaner? My fear is that it will do more harm than good.
Any thoughts would be appreciated.
Old Jul 17, 2012 | 09:12 PM
Silverick's Avatar
I have recently heard 'not good' things about internal engine cleaning and I found a pretty straight forward article about it. If I am reading this correctly.... it is saying that it may be a waste of time and may cause more harm than good...
I'll attach the link.
http://www.ehow.com/how_2111439_perf...flush-car.html
Old Jul 17, 2012 | 10:35 PM
Try the high dollar gas. Run a few tanks and see if that makes a difference. Seafoam and such will make the motor leak at all the seams.
Old Jul 17, 2012 | 10:52 PM
buttton's Avatar
Thanks to you both, thats what I was thinking. At this point the gunk may be holding it together.
Old Jul 18, 2012 | 03:02 AM
Ping is when the fuel/air mixture is ignited before/after when it is supposed to be. It can usually be fixed with some slight adjustment to the dizzy and/or running higher octance gas which burns longer and more complete.
I would start by filling the tank three times with 93 octane or higher gas and checking the timing.
Old Jul 18, 2012 | 12:46 PM
Don't put cleaner in the motor !! I would check the ign timing if it is pinging.
SeaFoam is great for adding to the fuel tank... NOT the motor
Old Jul 25, 2012 | 01:25 PM
Gorts 5th's Avatar
1/2 qt. transmission fluid for a days worth of easy driving does the trick for my brother and me make sure u put a new filter on it before you add the trany fluid and then change your oil with new filter you will be surprised at the gunk that comes out ans then as an after thought add 2oz of zinc assembly lube or some zinc additive remember todays oils do not have zinc additive in them for " emissions " and too wear out your motor faster
Old Jul 25, 2012 | 01:29 PM
Gorts 5th's Avatar
after 12 yrs of sitting all the carbon would have loosened from the inside of the block / valve covers so this can cause a dirt problem think about it
trany fluid has a high detergent content and anti corrosive properties
josehf34
15
Aug 2, 2013 07:22 AM
76 Doba
Mar 19, 2011 12:49 AM
69POLARA383
Oct 9, 2010 06:03 AM
elsmootho
Aug 17, 2010 03:18 AM
72Scampman
Feb 25, 2010 02:54 PM
