small block heads?
Old Jun 16, 2012 | 09:23 PM
fletchy38's Avatar
small block heads?
Okay i am learning that there are several types of factory heads on the small blocks. So what are the best factory heads and what years did they use them? I have nothing newer than a 91 3/4ton with a 360. and im not sure if its a mag or not. Thanks for any info!
Old Jun 16, 2012 | 09:35 PM
For a 360 LA motor the cast 308 heads from 1989-1991 trucks are good heads. For a 318 with 318 intake the cast 302 closed chamber heads are hard to beat.
Old Jun 17, 2012 | 04:10 AM
PK1's Avatar
PK1
The best small block heads were the magnums. The flow, better oiling, light weight 8mm valve and closed chambers make them the choice for performance motors.
The magnum started in 1992. I have been told that there were some cross over motors that had the better heads in 91 but I've never seen one.
The Mag Heads are prone to cracking between the seats but that's easy to check.
In addition to Bremereric's recommendation look for older "J" castings heads which came with larger valves.
Old Jun 17, 2012 | 04:55 AM
Here is some reading I hope will help.
http://www.allpar.com/mopar/LA-V8-en...ead-swaps.html
http://www.allpar.com/mopar/4bbl.html
http://www.buschis-place.de/sbheads_diff_porting.htm
http://www.buschis-place.de/swapping_mopar_heads.htm
http://www.waywardgarage.com/tech/SBchrysler.html
pipdog69
Mar 13, 2012 11:01 PM
68satellite
May 23, 2009 05:33 AM
Brent1960
May 17, 2009 04:25 PM
mahd
Apr 2, 2009 09:05 AM
bantam
Sep 12, 2008 11:25 PM
