Starter problems/electrical 73 duster please help
Old Mar 22, 2012 | 08:05 PM
USMC85RD's Avatar
Having issues with a 73 Duster. When the positive battery wire touches the battery the starter engages it justs spins and the keys are not in the ingnition please help just got home from afghan and would love to get the car running I do have a video of what it doing if that will help
Old Mar 22, 2012 | 08:50 PM
Check the starter relay and make sure you have no wires touching each other. The big stud and the starter solenoid wires are in real close proximity to each other.
Old Mar 22, 2012 | 09:31 PM
USMC85RD's Avatar
Would this explain why it does it without the key even in it ?
Old Mar 22, 2012 | 09:59 PM
Yep
Old Mar 23, 2012 | 06:38 AM
USMC85RD's Avatar
<img src="http://s1.craigupload.com/uploads/03_23_2012/img_20120323_17.35.37.4385160.jpg"/>
Old Mar 23, 2012 | 06:39 AM
USMC85RD's Avatar
Old Mar 23, 2012 | 06:40 AM
USMC85RD's Avatar
Is there any way I can get ahold of you I have pictures of the starter relay maybe u see something I don't
Old Mar 23, 2012 | 08:42 AM
Here is some help with posting pictures.
https://moparforums.com/forums/f62/p...pictures-2128/
Old Mar 23, 2012 | 08:50 AM
This is either
1 wiring problem to the starter relay coil
2 bad starter relay
3 wiring to the starter (assuming you have the relay -- to starter -- wires hooked up)
4 bad starter
Easy to troubleshoot.
1 FIRST Unhook both "push on" wires on the starter relay, try the cable If the problem goes away, it's in the igntion switch or the wiring to the relay coil
2 Unhook the wire right at the relay which is hooked to the "square" looking screw terminal, not the large stud. Try the battery. If the problem goes away, you have a bad relay
3 Unhook both wires at the starter, and try either JUST the large wire hooked to the large starter stud, or try a jumper cable from battery + to the starter large stud. IF it does not crank, the problem is the two wires going down to the starter from the relay are shorted together internally
4 With BOTH wires unhooked from the starter, in the test above, if the starter still tries to crank, then you have a bad starter / starter solenoid.
Old Mar 23, 2012 | 02:10 PM
Very well explained 440.
Old Mar 24, 2012 | 09:27 AM
USMC85RD's Avatar
It was a bad starter solinode I replace the starter and it started right up but now it's overheating like crazy the suspension was completely redone and so was the front end and ac was taken out I think the thermostat might be stuck I'm hoping it's not a head gasket.
Old Mar 24, 2012 | 09:28 AM
USMC85RD's Avatar
Thanks guys
USMC85RD's Avatar
Ill upload pics tonight
Old Mar 24, 2012 | 08:43 PM
Yer very welcome
Old Mar 25, 2012 | 09:23 AM
Probably air pockets in the block. Jack up the front of the car a little and run it several times.
duster3
Oct 2, 2013 02:46 PM
Steffany
Aug 20, 2012 09:44 PM
bobbylap
Feb 24, 2010 05:14 PM
BUNT217
Sep 6, 2008 12:34 AM
