Test for Vacuum Leak?
Old Nov 21, 2014 | 05:40 PM
Robert Weaver's Avatar
Question Test for Vacuum Leak?
What's the easiest/cheapest way to test for vacuum leaks around the manifold? Could you use Cigar thru a Vac Line? Or spray Carb Cleaner around it?
Old Nov 21, 2014 | 05:54 PM
Archer's Avatar
Robert -
Carb cleaner or even a water mist spray.
Listen for changes in sound or rpm.
Old Nov 21, 2014 | 06:04 PM
Only do the carb cleaner when the engine is cold, right? Can u do the Cigar thru a Vac line on a Carburetored Engine?
Old Nov 21, 2014 | 08:11 PM
moe7404's Avatar
get a small hose, VAC line or from your RC fuel line. with one end at your ear the other end at the manifold. engine running its not hard.
josehf34
36
Dec 16, 2014 06:05 AM
66coronetgirlie
Aug 9, 2010 10:41 PM
aka_rusty
May 12, 2010 06:56 PM
340CUDA
Mar 16, 2009 05:27 PM
Commando
Sep 23, 2008 07:35 AM
