Test for Vacuum Leak?
Nov 21, 2014 | 05:40 PM
Robert Weaver
May 2014
What's the easiest/cheapest way to test for vacuum leaks around the manifold? Could you use Cigar thru a Vac Line? Or spray Carb Cleaner around it?
Robert Weaver
Send a private message to Robert Weaver
Find More Posts by Robert Weaver
Nov 21, 2014 | 05:54 PM
Apr 2010
Long Island, NY
Robert -
Carb cleaner or even a water mist spray.
Listen for changes in sound or rpm.
Send a private message to Archer
Find More Posts by Archer
Nov 21, 2014 | 06:04 PM
Robert Weaver
May 2014
Only do the carb cleaner when the engine is cold, right? Can u do the Cigar thru a Vac line on a Carburetored Engine?
Robert Weaver
Nov 21, 2014 | 08:11 PM
moe7404
Nov 2012
get a small hose, VAC line or from your RC fuel line. with one end at your ear the other end at the manifold. engine running its not hard.
moe7404
Send a private message to moe7404
Find More Posts by moe7404
Vacuum leak through carburetor secondaries?
josehf34
36
Dec 16, 2014
06:05 AM
poly 318 vacuum leak help?
66coronetgirlie
10:41 PM
Vacuum Test Results Help Please!
aka_rusty
06:56 PM
Vacuum Leak
340CUDA
Mar 16, 2009
05:27 PM
Vacuum leak
Commando
Sep 23, 2008
07:35 AM
Tags
318
360
vacuum leak
Edelbrock LA vs Mangum Heads
01:43 AM
