Thermostat host leaks
Hello i have 1967 plymouth fury 3 and just replaced new radiator, water pump and thermostat. when i put it back on it started leaking from the host. I'm not sure if its from the host or the gasket. Please help
Yes i did and i just bought aftermarket thermostat hose, gasket and new thermostat. I dont know why its leaking. So after i drove just tonight, my tranny leaking from the radiator. My car's a fact 67 year model.
Are you using good screw type clamps? If the thermostat is leaking from the gasket ? the housing may be corroded.
Make sure you are installing it correctly engine/gasket/thermostat/housing along with a dab of sealer on the bolts also
I do not like to use silicon on gaskets , I use gasket cinch/permatex from a brush on can
Speedracer44
Mar 17, 2012 07:09 PM
Daviddzur
Jan 25, 2012 10:17 AM
ucfierocharger
Jan 30, 2008 06:44 PM
