Throttle bracket problem
Help! Need a few pics of throttle linkage. Story below but a simple job got increasingly complicated and now I can’t get it back together. Started a small project; installing an EGR valve for Smog inspection. Noticed aluminum intake was filthy. Tried cleaning it up. Decided to clean waterneck and install thermostat. Took off throttle linkage planning to put it back. It was greasy so took it off to clean and spray. The carb wouldn’t clear EGR. Bought a spacer.. now can’t figure out what I did with throttle linkage. I believe I may have moved it back one bolt location but not finding May pics in other posts. Any snap shot of brackets, location, and setup would be very helpful. this is a 79 W150. 360 auto. |
| All times are GMT -7. The time now is 04:22 AM. |
