TRW, thompson power steering pump kit ?
Does anyone know where I can buy a power steering rebuild kit for a 69-74 trw power steering pump? Big block 383.
Napa auto parts use to sell them..
(Post 142132)
(Post 142132)
I am pretty much positive the pump is a trw going by the notch in the back but what has me really puzzled is why the belt is riding on a angle, not square, surprising it doesnt fall off pulley, unfortunately its hard to get a pic of that but I was wondering if you can tell by looking at the mounting bracket what pump is suppose to be on it. Or is the bracket bent? i give up trying to locate a rebuild kit for the trw so now its either buy a trw, federal or a saginow but I dont want to have to replace everything due to the cost. Got any ideas?https://cimg4.ibsrv.net/gimg/moparfo...883edf2f7d.jpg https://cimg5.ibsrv.net/gimg/moparfo...7b27568f7d.jpg https://cimg7.ibsrv.net/gimg/moparfo...b8cd5ed32d.jpg |
Looks like the Federal Or Thompson pump....
Got a hunch.... I'm guessing you have a missed matched set of pulleys causing misalignment.... With the power steering bracket bent like it looks like it is.I would not dought that this might have had air conditioning at one point mounted on that engine. This is for the Thompson pump:>>>> https://www.napaonline.com/en/p/PSK7105 But with all that being said.... I think the the Cuda took the Saginaw Power Steering Pump... The pump you have on their is more than likely way to sensitive in the steering department? Just my 2 cents |
(Post 142185)
Got a hunch.... I'm guessing you have a missed matched set of pulleys causing misalignment.... With the power steering bracket bent like it looks like it is.I would not dought that this might have had air conditioning at one point mounted on that engine. This is for the Thompson pump:>>>> https://www.napaonline.com/en/p/PSK7105 But with all that being said.... I think the the Cuda took the Saginaw Power Steering Pump... The pump you have on their is more than likely way to sensitive in the steering department? Just my 2 cents I bought the car 6 yrs ago with the pump leaking but not as bad as it is now and although I would like a heavier feel to the wheel or maybe just harder to turn Im not really sure if the pump is to sensitive seeing I have nothing to guage it againest. Now you have thinking I should just suck it up and replace the whole system, but with what? |
(Post 142185)
Got a hunch.... I'm guessing you have a missed matched set of pulleys causing misalignment.... With the power steering bracket bent like it looks like it is.I would not dought that this might have had air conditioning at one point mounted on that engine. This is for the Thompson pump:>>>> https://www.napaonline.com/en/p/PSK7105 But with all that being said.... I think the the Cuda took the Saginaw Power Steering Pump... The pump you have on their is more than likely way to sensitive in the steering department? Just my 2 cents I emailed Napa Canada seeing I live in BC an was told they dont have the kit, I decided I would go to the closest Napa store to see if your part # would work, yuppers, yippee!!!! Get this though, your link shows the kit for about $18, it cost me $65 here!! Hopfully that will fix the leak. Now I just have to see if I can straighten the mount bracket or find a new one. Thank you very much for the part #, I have honestly spent atleast 10 hours online looking for a kit with no luck at all. If your ever my way I owe you some beers. |
(Post 142185)
