Vacuum Issue??
Old Sep 19, 2012 | 05:06 AM
70fury383's Avatar
Vacuum Issue??
Alright I have another problem. My car began to misfire about a week ago. It only happens when the throttle is pushed more than a quarter way in. I've already checked all the spark plugs and the wires are brand new. Now...my heater control valve vacuum line is spliced off of the vacuum advance line. When the heater is turned on it generally runs normal. This is making me think its a vacuum advance issue? How do i check to make sure it is vacuum advance..also could it be the canister on the outside of the distributor?..its a 2 bbl 383 btw
Old Sep 19, 2012 | 05:51 AM
Archer's Avatar
70 -
I know that most perf 440's don't need the vac advance, not sure about stock 383's. What is your initial and total timing?
Old Sep 19, 2012 | 09:47 AM
By "backfire" you mean popping back through the carb, and at least partially out the exhaust, and it gets worse the more throttle?
This has nothing to do with vacuum advance.
Most probably a flat cam, valve problem, or low ignition voltage, which can be caused by a number of things, not limited to
Bad primary voltage (the never ending problem of the bulkhead connector and 40 year old wiring)
bad coil
bad points/ condenser
poor connections, at, or bad ground, at, or bad ECU box
bad coil wire, bad cap or rotor
Old Sep 19, 2012 | 06:29 PM
70fury383's Avatar
Archer - I wish I could tell you that lol...I had a shop do all of that when they tuned my carb about a year ago..I'll have to check up on it tomorrow
440 - ill have to check some of that..although it can't be the coil, coil wire or cap..that's all new..at least I hope it's not any of them..that wouldn't make me happy
Old Sep 19, 2012 | 06:37 PM
70fury383's Avatar
Also..the problem completely vanished today..no stutter on either trip to school or the running around I had to do for my mom.....we'll see what happens tomorrow
Old Sep 19, 2012 | 07:12 PM
Archer's Avatar
70 -
Bad gas?
Old Sep 20, 2012 | 03:44 AM
70fury383's Avatar
I just thought that and came on to ask of that could've been it haha..I'm leaving for school in about 10 minutes so it'll be the moment of truth
19newport72
Mar 27, 2024 06:44 PM
stilllearning6
Oct 1, 2014 08:04 PM
66coronetgirlie
Aug 9, 2010 10:41 PM
340CUDA
Mar 16, 2009 05:27 PM
burnsy26
Oct 1, 2007 01:35 PM
