Vibration??
Old Jun 18, 2013 | 01:45 PM
mcatwood's Avatar
Question Vibration??
I have a 1975 W300 PowerWagon, that is powered by a 440,.
I was cruising down the hiway when all at once a viberation occured & I thought that I blew atire..pulled over & everything appeared alright.
There is no visible reason for the viberation, does this vehicle have a balanced fly wheel? it seems that the viberation is in that area? I pulled the dust cover & all seems normal there to?
Old Jun 18, 2013 | 01:55 PM
Check U joints and tire balance would be first
Old Jun 18, 2013 | 04:49 PM
Check the rims for balance wieghts.
Old Jun 18, 2013 | 08:24 PM
challenger's Avatar
check your lug nuts also
Old Jun 18, 2013 | 08:26 PM
pro-tech's Avatar
Is it a engine or driveline vibration???
Old Jun 20, 2013 | 05:26 AM
mcatwood's Avatar
It does it setting still, just by reving the engine
Old Jun 20, 2013 | 05:28 AM
mcatwood's Avatar
I believe it is the engine, is the 440 internaly balanced or does it have a harmonic balancer?
Old Jun 20, 2013 | 10:01 AM
Vibrations are the worst problems to solve. It could be the engine or trans. That is an important bit of info. First I would do a compression test & check ign - firing on all 8. Check the timing marks on the balancer . Next check the rocker arms, check for bent push rod? That's the easy stuff. next I would pull the pan and check for a broken piston skirt ? Then I would check the flex plate. IF every thing is ok ? I would consider changing the converter or at least have someone check it
Old Jul 29, 2013 | 02:15 AM
Highjinx00's Avatar
it could be anything from tires-driveshaft-wheel bearing. most of time the vibration could be felt from 55-70 mph.
maca
Aug 21, 2012 06:17 AM
Drakovich
Nov 28, 2011 04:17 PM
chezhed
Jul 18, 2011 03:11 AM
c011699
Apr 11, 2010 03:27 PM
bochyhawg
Feb 5, 2009 12:43 PM
