Want a 360
I second the magnum. Check out www.car-parts.com. It is a search engine for all on line junk yards. Using the magnum block with serpentine accessories it coimes with and add a manifold, your carb, little E fuel pump and a dizzy and you are rolling. Do compression before install, most I've seen with under 90k don't even need rings and bearings.
You may luck out with the block you want, but with machining and new slugs the mag may be less cost.
fletchy38
Aug 5, 2012 06:14 PM
DUST360
Sep 15, 2008 11:36 PM
