what will this cam do for me over stock
- HP improvement? '68 cuda,383 4bbl db/pmpr, 452 heads, edelbrock performer intake,4spd
street car
summit specs:
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,000-5,500
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 234
Duration at 050 inch Lift: 224 int./234 exh.
Advertised Intake Duration: 298
Advertised Exhaust Duration: 303
Advertised Duration: 298 int./303 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.466 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.488 in.
Valve Lift with Factory Rocker Arm Ratio: 0.466 int./0.488 exh.
Lobe Separation (degrees): 114
Camshaft Gear Attachment: 1-bolt
Computer-Controlled Compatible: No
Valve Springs Required: Yes
Camshaft Manufacturers Description: Fair idle, good midrange power camshaft. Requires 9.5:1 and higher compression, 2,000+ stall, and gearing. Good mild bracket racing cam.
street car
summit specs:
I'd like to answer your question with one of my own. What would you like the cam to do? Like what is the goal for this cam swap? What cam is in there now? I think if you're already running the 440hp grind it won't be a big enough difference to justify the effort and expense. Just my two cents though
THEhomelessONE
01-22-2017 03:43 PM
