Yeah, my head is cracked
Old Feb 21, 2013 | 08:36 AM
Shrug's Avatar
♫one of these things is not like the other♪
Look at the number 8 cylinder intake valve. See how nice and shiny? Like it has been steam cleaned. I think I have located my crack.
Old Feb 21, 2013 | 01:57 PM
pro-tech's Avatar
yup sure looks different to me. Can you see a crack??? It could also be the intake gasket leaking into the runner causeing the same thing. Being its #8 its right next to the water jacket. Be sure heads are expensive. keep us posted
Old Feb 21, 2013 | 02:23 PM
Shrug's Avatar
It is not the head gasket. The head gasket actually looks new. I think the guy who sold me the car tried to fix it by replacing the head gaskets.
The cheapest head I can find, since my head cannot be used as a core, is $500!
I am going to pick up a junkyard head this weekend for 50 bucks, and see if that helps.
Since I would have to save for like, 4 months to get 500 together.
Old Feb 21, 2013 | 03:53 PM
PK1's Avatar
PK1
http://www.ebay.com/itm/DODGE-DAKOTA...item2575a58c0d
This will work for you. I would highly recommend re lapping the valves to check the fit.
Old Feb 21, 2013 | 04:34 PM
Shrug's Avatar
First, thank you!
Second, has anyone gotten heads from them? This almost seems to good to be true.
I was going to hit the junkyard tomorrow, but this seems like an awesome deal!
Old Feb 21, 2013 | 04:44 PM
Shrug's Avatar
I had no idea how to lap valves. This is the first time I have actually disassembled a head. I found a lot of great videos on doing it.
Old Feb 22, 2013 | 02:53 AM
PK1's Avatar
PK1
I have used heads from them. They are NOT a performance shop and also do business under the name Clearwater Cylinder Heads. I though their work and product was good. I say lap the valves on the heads as a check on all R and R heads. Just use dykem on the seats and valves and use a fine grit as you are just checking the fit.
Old Feb 22, 2013 | 05:54 AM
pro-tech's Avatar
Is your engine an LA or Magnium there is a difference? Be sure to save yourself more problems.
Old Feb 22, 2013 | 12:00 PM
Shrug's Avatar
It is a Magnum. The guys said it was a Magnum 5.2L out of a 1996 Dodge Ram.
Old Feb 22, 2013 | 02:56 PM
pro-tech's Avatar
OK then thats what you should get. Did you see the crack or are you just hoping the head will fix it????
Old Feb 22, 2013 | 03:07 PM
Shrug's Avatar
It is a crack in a place I have no way of seeing. Apparently it is not uncommon for a crack to appear between the water channel and intake.
Old Feb 22, 2013 | 06:23 PM
Don't forget about the core ?? I would buy it if I needed one.
Old Feb 23, 2013 | 09:09 AM
Shrug's Avatar
Well I found the crack. I did a careful inspection of the chambers.
The number 8 intake chamber has a crack.
Check it out.
Old Feb 24, 2013 | 01:07 PM
pro-tech's Avatar
Put the valves back in the head and play dumb. save $$$$
Old Feb 24, 2013 | 10:42 PM
That's fixable. They will heat the whole head to 3-400 ?? degrees & then weld the crack. Then cover with heat blankets VERY slowly let it cool. Then Clean up the weld
Old Feb 25, 2013 | 06:02 AM
pro-tech's Avatar
That would be for the core charge.
Old Feb 25, 2013 | 06:38 PM
Shrug's Avatar
I already ordered the head that pro-tech suggested. They do not care if the core is damaged, or even assembled. Can hardly wait until it comes!
Old Feb 26, 2013 | 05:50 AM
pro-tech's Avatar
I know that feeling it seems like all I do is wait for stuff to come. Like my car back from the paint shop. I have a ton of stuff to put on the car and to do. Spring is fast approaching and I want it ready to cruise.
CantRamItDodgeIt91
Nov 22, 2010 06:12 PM
Live Wire
Oct 7, 2010 09:00 PM
79woodnick
Apr 27, 2010 08:55 PM
unclemike
Oct 11, 2007 06:31 PM
ProEmaster
Mar 1, 2007 12:19 PM
