Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   340 Roadrunner Transmission delima! (https://moparforums.com/forums/f82/340-roadrunner-transmission-delima-11260/)
Idrivemopar Dec 17, 2011 03:56 PM
So, back in the day, 1984, my transmission failed on my 73 340 roadrunner, and it was replaced and i never thought twice about it until today when i decoded the numbers on it. come to find out the replacement that was put in is from a 69 or 70 dodge truck.
I know that parts are interchangable between 727 units, but who knows what torque converter is in it, and what else, but that will have to change anyway to handle a different stall for the engine.
My question, since i am starting a complete restoration of the car, would it make sense to just rebuild that existing transmission to match my engine build or just spring for a high performance aftermarket transmission?
Any advice, please let me know!
TVLynn Dec 17, 2011 05:20 PM
Unless you are planning a wild engine for your Sat, Re build the trans you have.
