4 speed manual swap D100
Old Jun 29, 2018 | 04:50 AM
Gene75D100's Avatar
In the process of swapping out a 225 for a LA 318.
its 75 model 318 truck currently has a 3 speed manual and want to put a 4 speed manual. What is the best one to use and would a early 90 model 5 speed work?
Old Jun 29, 2018 | 06:37 AM
A 833 overdrive 4 speed would be my first choice. The 90s 5 speed not sure, I’d have to ask my mechanic son.
Old Jun 29, 2018 | 06:11 PM
NV 3500 5 speed can work probably just strong enough if your not heavy towing. 5.2 magnum has a slight balance difference than LA so flywheel will need to be checked for neutral balance, hydraulic clutch on a fork so you could build a mechanical pedal. Shawn's hydraulic was 6:1 and hard to push.
Gene75D100
Jun 29, 2018 04:49 AM
HawaiiEmo
Jul 26, 2017 06:51 PM
Boivin913
Oct 2, 2015 02:15 PM
tfaryniarz
Sep 3, 2013 09:10 PM
Mchury
Apr 6, 2013 12:35 PM
