46re compatability
Old Nov 25, 2019 | 12:55 PM
BadRobot's Avatar
46re compatability
pre 2000 46re -40F in 2000 RAM 1500 w/5.9L.
Customer brought vehicle in due to high rpm at highway speeds. Tested w/scan tool attached. not shifting into 4th at all. no codes. fluid temp always at -40F.
Temp sensor changed to new design in 2000, tranny has older design sensor indicating 1999 or older, pan has SAE bolts so it may be several years older.
Will the 2000 control module talk correctly to this old tranny?
Old Nov 25, 2019 | 04:46 PM
Check battery voltage, I had one not go into OD because of a bad battery.
Old Nov 26, 2019 | 09:09 AM
I'm Just going to shoot in the dark and say not it will not command it... But I am not that savvy!!!!!
I do think you have got a P0711 type code on the trans Temp Sensor for "No Temp Rise after start up" ????
But in the 2000.... The 3-4 Solenoid is controlled by the PCM. I would look to see if it is getting commanded and or has voltage to the solenoid pack?
Just my 2 cents
felipec2106
Dec 4, 2014 03:09 PM
jbwinkle
Oct 12, 2012 02:46 AM
Beerstop
Nov 5, 2011 11:17 AM
wilfred
Jan 30, 2011 07:04 AM
cide
Sep 8, 2008 08:47 AM
