46RH trans part #series
Old Aug 16, 2013 | 02:11 PM
Snoblor's Avatar
I'm looking to find a 46RH transmission. Does anyone know what the part number series (stamped on the drivers side above the pan) would be for all years that it was made? The part number I have to check against is a 52118328 but doesn't match anything in the junk yard. I'm building a truck, so don't have a trans to reference. So if I had a reference list of the entire series of numbers, I could check to see if I'm pulling the correct trans. Or is there an easier way, I know about the two and three wire plugs, but would like to be 100% sure before I go through all the work to pull it out. Thanks in advance for your help!
Old Aug 16, 2013 | 03:11 PM
Not sure on numbers but you need an early 90's trans
Old Aug 16, 2013 | 04:38 PM
moe7404's Avatar
check out these guys. http://www.areds.com/ i have known these guys since 1969. ill bet they can answer ANY Q.
Old Aug 16, 2013 | 06:35 PM
This may help too ! How too hook it up...
http://www.transmissioncenter.net/SwapInformation.htm
Old Aug 20, 2013 | 06:32 PM
Snoblor's Avatar
Thanks you guys! The search has ended. Found one as a core! Wanted to rebuild it anyway! Man, they are really hard to find! I'll pick it up Friday! Thanks again!
scotts74birds
Dec 15, 2016 09:03 AM
orangesteve
27
Apr 8, 2013 02:59 AM
maca
Jan 20, 2013 02:49 AM
maca
18
Jan 14, 2013 04:24 AM
wilfred
Jan 30, 2011 07:04 AM
