68 8 3/4 greaseing the wheel bearings
Old Jun 10, 2011 | 09:46 AM
bboogieart's Avatar
Question 68 8 3/4 greaseing the wheel bearings
How hard is it to just repack the rear wheel bearings?
I am going through the brakes in my '68 New Port. Replaced the pinion seal and thought I should repack the rear bearings while I am under here. Can I just pull the axles out and repack the bearings and replace a new seal or is there more to complicate the matter? Thanx for any input.
Old Jun 10, 2011 | 01:14 PM
You can grease them. as you said just pull the axles . Replace the seals too..
Don't forget to reset the axle preload You should be able to move the axle in and out about the thickness of a dime..
Old Jun 10, 2011 | 02:09 PM
bboogieart's Avatar
TV Lynn,
Thanx for your input.
inri
May 25, 2013 10:13 AM
hippo204
Sep 2, 2010 08:17 AM
Bossta
Mar 2, 2010 08:13 PM
Slice
Feb 7, 2010 07:47 AM
pjmopar
May 15, 2009 01:48 PM
