727 shift
Old Jun 10, 2012 | 10:49 AM
chicisles's Avatar
727 shift
I drive a 1991 doge ram 250 with the 318 engine and 727 trans. It does not change down from third gear automatically. It will change up through all down from 2 to 1 but not from 3 to 2 I have checked the throttle linkage which was stuck in one position, I freed it off but no improvement thanks , greetings from Scotland
Old Jun 13, 2012 | 04:08 PM
70Coronet's Avatar
I am having a similar problem right now sometimes stays in 3rd when I come to a stop, it should just be a simple kickdown adjustment, I will be doing it tomorrow on mine and will report back with some more details for ya
Old Jun 14, 2012 | 09:44 AM
chicisles's Avatar
that is another symptom, stays in third when stopping and vibrates, just manual change to stop vibrating. thanks for your help
Old Jun 14, 2012 | 01:58 PM
Goes back to the kickdown linkage, governor malfunction, Kickdown servo band or linkage. I would check all of the linkage adjustments . After that I would change the fluid and filter
Old Jun 14, 2012 | 03:19 PM
70Coronet's Avatar
Angry
Not much help here, adjusted mine this afternoon, turns out I had it backwards, when I was at wide open throttle the linkage was getting pulled forward instead of pushed toward the back of the car, made the adjustment on mine and now the rear rod(vertical one) hits the back of the cylinder head(not sure if it has something to do with them being magnum heads but I doubt it) and is worse than before. So I will give it another look tonight and might just order the cable kit through bouchillion, in your case just make sure the linkage is all the way back when the throttle is fully open(check at carb and trans) sorry I couldnt be more help-kinda stuck on this one myself
64fury
Jun 14, 2016 07:15 PM
72D100dodge
Apr 15, 2012 07:15 PM
64fury
Feb 2, 2010 06:25 PM
71satellite
Jan 9, 2010 04:44 PM
cobaltdkd
Jul 19, 2008 08:18 AM
