Struggles in Drive
Old Jun 15, 2012 | 09:36 PM
curtjr4's Avatar
Struggles in Drive
So, I have a 1968 Chrysler Newport. I do believe that it actually has a Torqueflight transmission in it, but here's the problem. When I reverse, the car will move flawlessly without my foot on the gas. So when I put the car into drive, it really struggles to move... almost as if the parking brake is slightly engaged. As I said, it is fine in reverse... but when it's in drive... it sure needs quite a bit of gas to roll forward. It will not move what so ever without me putting pressure on the gas.
I really have two thoughts right now, but could use input. It can either be a transmission problem (hope not), but maybe it could be something with the wheels? I just purchased the car yesterday, and on the front it has some Tigerpaw H78-14s (From the 70s. No tred, so I need to get those replaced). I'm really hoping it isn't the transmission giving me trouble, and I hope it is just something with the wheels. Any thoughts?
Thanks!
Old Jun 15, 2012 | 10:41 PM
Raise it off the ground on Jack Stands Check for brake drag
Old Jun 16, 2012 | 07:21 AM
70Coronet's Avatar
X2
Old Jun 16, 2012 | 08:15 AM
Tranny rebuild time.
Old Jun 16, 2012 | 05:00 PM
MrOldart2U's Avatar
Unfortunately I agree... Does it do this all the time or only when 'cold', IE: first drive of the day?
Old Jun 17, 2012 | 07:37 AM
curtjr4's Avatar
I put it on the jack, lifted it up and it had resistance. I put the spare on and it is not struggling as much. I'm getting the bearings worked on, though. Look at the attached picture. Something else isn't right based off of how it is worn (and none of the other tires are like this. They still need to be replaced, but it isn't this bad). I've talked to a few people and let them listen to it turn and they think the bearing needs work. Maybe later I can put it back on the jack and get a video of how it sounds when I spin the wheel. It makes a squeaking noise as if metal is rubbing together (whether it's the spare or not) as the wheel rotates.
Old Jun 17, 2012 | 07:51 AM
curtjr4's Avatar
Oops. If this turns out to be a double post, I am extremely sorry. I just thought I'd at this in. The car won't roll when in drive. But once I give it gas, I can let go of the accelerator and it will roll.
And it does it all the time. Not just when it's cold. But as I said... I think there's something wrong with the wheels. I'm getting the bearings worked on and I'm going to ask them to look into what it may be if the bearings aren't the cause. I'll let you guys know the results sometime next week (I'm also replacing all 4 tires...)
Old Jun 17, 2012 | 04:06 PM
MrOldart2U's Avatar
If you are getting a squeaking noise from the bearings, they are probably toast.(literally), A bearing service is a good place to start, and while there make sure the calipers arent 'hanging'(if disk) or the brakes are in good shape and not adjusted out to much 'dragging' (if Drum). Also it looks like its in the need of a good front end alignment which CAN increase rolling resistance causing a small portion of what you are experiencing. Sounds like a combo of things you maybe have going on.... And maybe it isnt trans related at all... G/L and keep us informed....
Hmmm post # 318...
Old Jun 17, 2012 | 05:01 PM
curtjr4's Avatar
Well, I got good news. The good news is that the car is rolling now. I took it out around my neighborhood, stopped at a stop sign... and then I let off of the brake and it went by it's self. So that problem is all good at this point. As for the bearings, they aren't terribly bad. Yes, I am getting them looked at but I am sure I could still get some life out of them.
Now that it rolls at a stop sign when I let go of the brake... it doesn't want to move by its self when I initially shift into drive. It'll move like it should in reverse... but with drive, I need to give it gas (I slowed down from 25, stopped, then it went). Should this be normal behavior? I mean, it rolls. Just not initially when I put it in drive.
Old Jun 17, 2012 | 08:16 PM
MrOldart2U's Avatar
A little hesitation isnt fatal, but could be a sign. Try and do a trans service first...
Old Jun 18, 2012 | 01:03 PM
curtjr4's Avatar
Alright, will do. I'll take it in sometime and get the transmission looked at. If I continue driving it as it is, do you think it would stir up more problems? I'll definitely get it looked at, but just curious.
Off topic: This isn't the section to post this in, but I am in need for a washer fluid reservoir. Part #2771950. If anyone has any ideas as to how I can get one, please shoot me an IM. It'd be very much appreciated.
scotts74birds
Apr 10, 2010 05:32 AM
hellzombiex
Apr 14, 2009 09:59 AM
cudaneil
Mar 25, 2009 02:20 AM
71RR08
Aug 14, 2008 07:36 PM
80VDuster
Jul 26, 2008 11:58 PM
