727 Torqueflite - Transmission Cooler Lines?? HELP
Old May 16, 2014 | 04:25 PM
hckrphil's Avatar
Hi Everyone!
Hooking up my transmission cooler as we speak.......... which is the "OUT" and which is the "IN" hookups on the transmission?
I want to make sure I pump the fluid to the TOP of the cooler and let gravity assist with the return.
Thanks a ton!
~Phil
Old May 16, 2014 | 04:30 PM
hckrphil's Avatar
I believe the nipple to the REAR (near yoke) is the RETURN line correct??
Thanks everyone!
~Phil
Old May 16, 2014 | 05:20 PM
moe7404's Avatar
yep the the left rear is in. be sure and use ONLY steel brake tube. OR high pressure hose . NEVER NEVER NEVER use copper. or gas fuel line for a carbed engine. this is one of the places that the factory DID know what they were doing. iam trieng to find the pt no for the external filter.
Old May 16, 2014 | 05:23 PM
moe7404's Avatar
i found it its a cut and paste. sorry.
the old auto zone 2210 magenfine filter is no longer available at auto zone. BUT i did find the same thing as JX-160 brand-- ATP. at a real parts house uses 3/8" tube. ONLY use high pressure hose. SAE J1019 217 psi working. NOT fuel hose for a carb engine.
LaurenMagnum360
Feb 7, 2014 05:49 AM
68GTX440
Sep 30, 2013 09:22 PM
godprovoked
Jul 13, 2012 02:44 PM
hubcap
May 28, 2008 05:24 PM
hubcap
May 6, 2008 06:26 PM
