727 transmission problem
Old Sep 15, 2013 | 03:19 PM
dart75's Avatar
I have an automatic 727 transmission in my 75 dodge dart,and it seems to slip a little bit when its cold , but when the car starts to warm up after about 10 minutes it doesn't want to move at all, in any gear, any idea what that might be?
Old Sep 15, 2013 | 04:56 PM
Start the car....Put it in Neutral....And Check the trans fluid.....Should be half way to the full line when cold...
Old Sep 15, 2013 | 06:46 PM
moe7404's Avatar
did you put a 440 infront of a 383 trans?
Old Sep 16, 2013 | 07:14 AM
dart75's Avatar
okay i'll try that, and its a 340 small block with the 727 auto,
Old Sep 16, 2013 | 11:46 AM
Either the fluid is very low or the front pump in the trans is broken
Old Sep 16, 2013 | 11:55 AM
moe7404's Avatar
is the trany O.E.M. 318?
Old Sep 21, 2013 | 03:26 PM
dart75's Avatar
Just checked the fluid, it's good on fluid, but you can hear a Whiney sound when you give it noise in gear, especially reverse, could it be the transmission pump going out?
dart75's Avatar
When you give it gas in gear, sorry
Old Sep 23, 2013 | 04:03 PM
First Are you aware you check the fluid with the car running ? Easy for a newby to over look.. Other wise no drive or reverse a Pump failure possible converter failure
Old Sep 23, 2013 | 04:27 PM
Time for an overhaul....
hubcap
May 6, 2008 06:26 PM
lslater
Apr 28, 2008 10:33 AM
ucfierocharger
Aug 4, 2007 07:37 PM
txbullets
May 18, 2007 03:36 PM
blindman
Apr 16, 2007 02:02 PM
