76 W100 727 problem.
Old 05-02-2013 | 04:16 PM
04 Diesel's Avatar
I have a bad tranny leak, tranny fluid all over under the truck, dripping from bell housing. I was told it might be the front pump seal, so I pulled the motor and replaced the seal. I also replaced all the freeze plugs and valve guide seals. I put the motor back in and took it for a drive and it is still leaking from the bell housing. Im not sure what to do next, I looked at the torque converter and I didn't see any cracks, there was no grove in the shaft. Also the dip stick tube is not leaking, any ideas?
Old 05-02-2013 | 05:40 PM
It still could be the converter. Did you reseal the pump or just change the converter seal ???
Old 05-02-2013 | 06:32 PM
Gorts 5th's Avatar
Smile
It is possible for the pump housing seal/ O-ring to fail the heat will dry out the O-ring and it will shrink
how does the trany run, no problems shifting when cold?
it's also possible for the weld on the yoke to develop a small crack rare but possible
did you pay attention to a leak trail when changing the seal sometimes it s a clean path where the oil has been traveling
some suggestions.
Old 05-02-2013 | 06:44 PM
04 Diesel's Avatar
I just did the converter seal.
Old 05-02-2013 | 06:47 PM
04 Diesel's Avatar
some suggestions.
The tranny shifts fine, even cold. Yes there was a clean path where it is leaking, it is coming out where the torque converter yoke slides in the tranny.
Old 05-02-2013 | 11:37 PM
jacilynn_s's Avatar
sounds exactly like a hairline crack in the torgue converter pump drive tube. Look for a hairline almost invisible crack from the tooth towards the torgue converter. It could be the weld as well but more likely the shaft. It happens when people slam the transmission into gear when its cold and the engine is still on fast idle.
Old 05-03-2013 | 06:29 AM
04 Diesel's Avatar
Ok, I guess Im going to take the tranny out to get the torque converter out. Can I put a lock up torque converter in my 727? Or do I need something else?
Old 05-03-2013 | 07:29 AM
jacilynn_s's Avatar
you can put one in and it will work just not lockup since there is a circuit in the transmission for a lockup that you probably don't have.
Old 05-03-2013 | 09:33 AM
There are some lock up 727 trannies but based on the year of the truck, I'd say its non-lockup (I could be wrong tho). It's best to check before buying it.
Old 05-03-2013 | 10:32 AM
04 Diesel's Avatar
I found a guy that has 2 torque converters for sale for $75.00, one is a 10 3/4 inch and the other is a 11 inch. I don't know what I have in my truck, its in the truck so I cant measure it. He says both will fit, witch one would be better? Will one lower my rpms?
Old 05-04-2013 | 07:09 AM
Gorts 5th's Avatar
i Would not mix lock up and none lock up converters there are some differences at the end of the input shaft and inside the torque converter. See pics.
Don't you have a local transmission parts house? i would buy a rebuilt factory converter from a parts house and i would have the choice of 1200-2000 rpm a factory high stall from mopar is a fine converter those engineers knew what they were doing and any higher stall is just not-practical for the street.
Attached Thumbnails 76 W100 727 problem.-p1020422.jpg   76 W100 727 problem.-p1020421.jpg   76 W100 727 problem.-picture-155.jpg
Old 05-04-2013 | 01:10 PM
Not sure BUT the 904 the lock up and Non lock up have a different input spline count, will not interchange. I am assume the 727 would be the same
Old 05-04-2013 | 08:35 PM
04 Diesel's Avatar
Didn't my truck come with a 11 inch converter? Ill know when I pull the tranny.
Old 05-05-2013 | 08:08 AM
Gorts 5th's Avatar
Smile
That's the thing with mopar torque converters the 1200 stall and the 2000 stall are the same size the only way you could tell in the old days was a little oval sticker on the converter "H S, LS" the last converter i bought 2000 stall w, lock up for my 46 re now in my 86 5th ave the stall is perfect for the street everywhere i go she cruises at 1800 2000
Old 05-05-2013 | 10:37 AM
04 Diesel's Avatar
Ok, so I need to look for a LS? Right?
Old 05-05-2013 | 09:52 PM
Gorts 5th's Avatar
Smile
if you can find a local re-builder he will have both....
that's how i came to get mine i asked for a 2000 rpm lock up and they sold me one, you got to have a local re-builder re manufacturer wholesaler in your area.
Old 05-06-2013 | 01:05 AM
You could try to pressurize (air) your converter to see if it actually leaks before just replacing it ..
Old 05-06-2013 | 07:35 PM
04 Diesel's Avatar
Ok, found a new converter for $50, it was for a rv. What do you think? Im not going to get it yet, I need to find out what size I have first. Just want to know what you guys think.
Old 05-07-2013 | 09:09 PM
04 Diesel's Avatar
I pulled the tranny and transfer case today, I don't think its the torque converter, I did not see any cracks. Now what?
Old 05-12-2013 | 08:18 AM
Gorts 5th's Avatar
Smile
post pics if you can
Old 05-15-2013 | 04:21 AM
04 Diesel's Avatar
Ill try to get some pictures, I took the pump out and noticed the bolts for the pump were not very tight. Only 2 of the bolts were tight enough to pop when I was taking them off, what should these bolts be torqued to? The pump seal behind the pump is good, the o ring seal that goes around the pump looks fine.
Old 05-15-2013 | 05:34 AM
The o-ring you can probably reuse but if the seal behind the pump is paper, then you should replace it.
As for the torque of the bolts, 175 in/lbs. (found doing a Google search but can try to verify tonight in my 727 handbook).
Old 05-15-2013 | 06:16 AM
Gorts 5th's Avatar
Smile
hope they can post
pics of the pump gears and housing will show if the wear is enough to warrant replacement if you go online and search for Automatic transmission service group [ATSG] you can find manuals and videos with specifications
i would be careful re-using the o rings when old the can dry out be come brittle and not reseal pick up a o-ring kit at a local suppler of go to [PACT]
Old 05-15-2013 | 12:26 PM
  #24
I don't care what the seals look like !!!!!!!!!! REPLACE THEM, gasket O ring and seal Check the front pump bushing it should be staked into position if it is turned ? replace it too....... you can't tell always by looking at them. It is a lot for work to try and save $10
Old 05-15-2013 | 08:40 PM
  #25
04 Diesel's Avatar
Im taking the tranny in to be rebuilt tomorrow. I would never use any of the old seals.
Old 05-15-2013 | 08:53 PM
  #26
Gorts 5th's Avatar
Smile
your good now
Old 05-16-2013 | 11:53 AM
  #27
Zoomer59's Avatar
Just pull the trans and take the convertor to a trans shop and they will match it for you.all you need to know is engine,weight class, 2 or 4 wheel drive etc etc.
Old 05-25-2013 | 06:38 AM
  #28
04 Diesel's Avatar
I had the tranny rebuilt, I will start to put it back in today.
Old 05-26-2013 | 08:08 PM
  #29
04 Diesel's Avatar
Tranny is in and the transfer case is going in tomorrow.
Jlbmad30
02-13-2015 09:58 AM
psytropic
08-24-2010 05:18 PM
wildbill2009
02-11-2010 04:18 AM
wildbill2009
01-10-2010 05:34 PM
Iskone
09-03-2009 09:22 AM
