8.75 true grip
Old Mar 25, 2014 | 04:27 PM
440 aspen's Avatar
8.75 true grip
Does anyone know where I can find an 8.75 true grip clutch? I have a 741 open carrier and i want to get both wheels spinning but i cant find just the clutch. I can only find 3rd members with it already installed. Any help would bve much appriciated.
Old Mar 26, 2014 | 06:13 AM
pro-tech's Avatar
It is called a SURE GRIP...And you will have to change the CARRIER you cant just put a clutch in a open rear differential...The SURE GRIP CARRIER will have the clutches or cones in it...If you are using this car for track use only you can put a spool in it which is much much less money but it cant be driven on the street...Bill
Old Mar 26, 2014 | 10:49 AM
741 is small pinion, why not get a 742 or a 489 carrier much stronger BUT there are newer types of sure grips available for the 8 3/4
mystarcollectorcar.com
Mar 5, 2010 06:05 PM
68 Sat
Mar 22, 2009 08:41 AM
1dart2nv
May 27, 2008 03:50 AM
deadkelly
Feb 20, 2008 08:20 AM
BB1
Dec 9, 2007 11:36 AM
