904 hard driwing when cold
Old Nov 2, 2015 | 03:27 AM
Rute66's Avatar
Hi
I have a 1970 challenger with 340 and 904.
When the car is cold the transmission have a hard time to make the car move, I need to give high throttle to make the car move.
When engine and transmission is hot, it works perfect.
Is it time for a new transmission ?
Regards
Tony
Old Nov 2, 2015 | 10:36 AM
during it's life someone transplanted a 340 into your car.... THE factory NEVER put a 904 behind a 340 motor. Your 904 probably has leaking seals.
Old Nov 2, 2015 | 11:21 AM
Might be something as simple as fluid and filter, I've had the filter plug up and not pull fluid when cold.
Old Nov 3, 2015 | 02:02 AM
Rute66's Avatar
Hi
Yes it is born with 318.
I will try the filter first Thanks.
What o rings are you meaning ?
Regards
Tony
Old Nov 3, 2015 | 06:02 AM
Archer's Avatar
Tony -
Do a full tranny tune-up first.
New filter, fresh fluids - including what's in the torque converter, if possible. Making sure all the lines are open by flushing them, if possible.
When you drop the filter, you might want to drop the valve body as well and see how the stuff on top of it looks. Checking/adjusting the bands might be a good idea, since you're there.
Sorry, never worked on a 904, assuming the set up is similar to a 727.
Old Nov 4, 2015 | 03:13 AM
Rute66's Avatar
Tks.
When I read about adjusting the rear band, I can see some places they want to turn back the screw 4 turns, and some other places only 2 turns ?
What is correct?
Tony
Old Nov 4, 2015 | 08:03 PM
Start the car.... Put it in neutral and for a couple minutes on warm up.... Then put it in drive.... That should help with the common "Morning Sickness"....
It is also referred to as Converter drain back.....
Old Nov 5, 2015 | 01:19 AM
Rute66's Avatar
Hi
Is there a way to solve the problem?
(Converter drain back)
Regards
Tony
Old Nov 5, 2015 | 05:26 PM
Drag Pak's Avatar
Originally Posted by Rute66
Hi
Regards
Tony
If draining , flushing and installing a new filter and fluid does not work?
One of my old 727's we took the valve body apart and use some 2000 or finer grit wet sandpaper on all the valving to remove any varnish buildup and possible burrs on the valves. Especially the torque converter control valve. This procedure cured this one.
On my current 727/904 race transmission, I found one of the hooked steel seal rings on the back of the pump badly worn. Once I replaced the hooked steel ring - problem solved.
$0.02
Old Nov 5, 2015 | 05:38 PM
Yes.... Installing a new pump takes care of the problem... But at that point you might as well freshen up the trans complete....
Just My 2 cents....
Old Nov 6, 2015 | 01:51 AM
Rute66's Avatar
Tks.
Regards
Tony
Old Nov 13, 2015 | 08:55 AM
Rute66's Avatar
727 truck tailhousing instead of 904
Hi
I have a 727 SB with truck tail housing.
I can see the transmission is longer so I need another yoke and driveshaft.
I can also see it missing mounting holes for the shifter rod bracket, can I use the tailshaft from my old 904?
Do I need anything else?
Regards
Tony
Dave E
Mar 18, 2014 05:02 PM
mblackmon
May 17, 2012 12:12 PM
will d
May 9, 2010 09:41 PM
Cure
Apr 21, 2010 10:32 PM
68 Sat
Feb 7, 2010 05:24 AM
