904 late upshift/early downshift
My 69 cuda (new to me) is upshifting late(+- 40mph) at partial throttle and downshifting early (+- 30mph coasting). Fluid level is normal full. I have the maint. manual so the adjustment procedure is available but I thought maybe one of you experts could shortcut me to the right adjustment point.
Thanks
Bud
Thanks
Bud
I don't want to "kick a dead horse" on this thread, but did you replace it with an OEM retention spring, or a universal spring that just happened to work? I have the same issue right now on my 904, (well, similar issue, my car doesn't run at the moment but I am missing that same spring.)
The reason I ask is, I couldn't locate an OEM spring, I used a universal that kind of worked. I'm not a big fan of cobbing things together, so I'd like to get my hands on an OEM spring.
If you did use an OEM spring, where did you buy it from?
If you used a universal spring that works maybe better than mine, where did you buy it and what size?
rcknrolfender79
Nov 23, 2020 09:19 AM
CantRamItDodgeIt91
Aug 11, 2009 11:54 AM
