A518 and lockup converter
Old Jan 21, 2014 | 02:02 PM
josehf34's Avatar
Hi!
I have the follow doubt, if somebody can resolve it, I'll be very grateful:
If I'm right the A518 46RH/RE is a non-lockup transmission but what happens if somebody install a lockup torque converter on it? will work or just will broke the transmission?
What will happen if the guy that has installed the lockup torque converter enable the lockup at WOT or going down a hill (maybe will get better engine brake?)?
I ask this because in some forums I've read that the lockup reduces the lifetime of the transmission but is very helpful on performance, mpg and keep the transmission cool
Old Jan 21, 2014 | 02:44 PM
DodgeAddict's Avatar
All 518's 92 & newer were lockup rh or re
Old Jan 21, 2014 | 03:00 PM
Dodge addict I believe is right... On earlier 904's and such the lock up and non lock up had a different spline count on the converter so they would not interchange
Old Jan 21, 2014 | 03:50 PM
josehf34's Avatar
I'm a little confused. If all the A518s are lockup why the transmission OD switch connector sometimes only has de hot wire for the OD unit and in other transmissions has a Hot plug for the lockup?
1992challenger
Mar 3, 2014 07:59 AM
josehf34
Feb 3, 2014 08:54 PM
maca
Oct 16, 2013 04:51 AM
drognlin
Oct 14, 2010 04:11 AM
Aug 28, 2008 04:00 PM
