Differential chatter
Old Mar 20, 2016 | 02:25 PM
scotch's Avatar
I have a 76 Cordoba with a 400 CID. It has a 271 sure grip differential. 53K original miles and like new. Recently, the differential will chatter and clunk upon initial driving when turning. After some miles it goes away. I changed the fluid and put in an additive for this problem (clutches). No avail.
What would be the best solution for this problem.
Old Mar 20, 2016 | 02:39 PM
Ive had the clutchs dry out over time with just sitting, if you can find an open aria to drive in a large circle at 20 mph for a few minutes it will lube the clutchs. They are dry or ***** out. Going in a circle at speed will hopefully get the lube between the chutch disks.
Its worked for me.
Old Mar 20, 2016 | 07:55 PM
Archer's Avatar
scotch -
OK, just going to throw this out ... do you really want 2.71s in there?
Just saying.
If you can afford it, 3.23s or 3.55 would really wake the car up. The gear change would give you a chance to inspect the carrier.
Old Mar 21, 2016 | 03:22 PM
scotch's Avatar
Thanx - I will try this
Its worked for me.
Old Mar 22, 2016 | 05:52 PM
Going to a 3.23 or 3.55 from a 2.71 May require a carrier change also..
mrindiglo2004
Aug 8, 2011 04:06 PM
bremereric
May 5, 2011 10:08 PM
Barfly
Mar 1, 2011 02:39 AM
67gtxclone
Apr 7, 2010 01:56 PM
danuwells
Aug 5, 2007 10:58 AM
