Disconnecting shift linkage
Old Jan 18, 2014 | 10:35 AM
360dartcustom's Avatar
I have 76 dart with column shift and a 904 tranny
I have everything disconnected to drop the tranny EXCEPT the damn shift linkage. I can't figure out how to disconnect it doesn't tell me how to do it in the Haynes it just says how to loosen it up and there's no bolts to take off
Old Jan 18, 2014 | 10:46 AM
The link down at the trans should have a sliding adjustment with a set screw bolt, and the end right at the trans lever should have either a spring clip or a cotter key
I don't recall, seems like the upper end at the column has a rather weird sort of "snap in" plastic ring. "The I junked" I was not that concerned with saving that stuff
Old Jan 18, 2014 | 11:22 AM
I'll look for that spring clip. All I saw were those weird snap in bushings that I didn't want to break in fear I'd never be able to find new ones lol.
Old Jan 18, 2014 | 12:02 PM
Just loosen the pinch bolts at the trans on the shift linkage pry up with a screwdriver & disconnect the cross bar bracket from the trans
64fury
Jun 14, 2016 07:15 PM
Tjl311
Oct 21, 2012 06:52 AM
70Coronet
Apr 20, 2012 04:28 PM
olebrowndodge
Feb 1, 2011 07:30 PM
64fury
Feb 2, 2010 06:25 PM
