Help choosinggear ratio
Hey guys, need some input. Starting to rebuild my 9.25 rear end, looking for input...Rear wheels are 20", trans is 727 from a 69 polara ( not sure if that dictates gear ratio)
Thanks
Thanks
What is it going into? Is the car just a cruiser or strip? How tall are the tires? Motor details? Convertor size? These all play into what gear ratio to use. Normally a 3.55 is a good compromise.
john
john
'74 satellite, 528 stroker, tci ultimate streetfighter (4000+), 24" tire height, mostly street and some strip
Okay remember that torque, weight and such are major players when someone is giving you advice on a torque convertor. I usually talk to a torque convertor builder and let him decide what I need. At that time he will also ask you what gear you are running. I would not go with 4000+ stall and 3:55 rear gears. My car will probably never see the strip and is lighter than yours. My 9 1/2" convertor stalls at 3200 and my rear is a 3:55. It runs in the 3000+ RPM range at 65 mph.
Either Paul with Turbo Action or Rick with A&A Transmissions
With such a small tire,go with a 3.21 gear. And like bremereric said, convertor is too loose,get a tighter convertor otherwise all the low end torque a 528 stroker makes is wasted. Why such a small tire? Looking for that low rider look?
Thats right about where I am at when going 65mph. Ill test it today and get back.
john
You have a 528, auto, 4000 stall, 24" rubber and your driving it now at 65mph turning about 3000rpm. If I have that right do you know or can you calculate the gear that is in it now. It sounds like a 3.55, I would stay with the 4000, change to a 3.9-4.1 with a solid pinion spacer but increase tire size.
Two things I see you have so much power you'll tear those tires off or wrap up the rear axle breaking U-joints or more. Sounds like your serious about your launch and I would recommend a rigid mechanical traction device and cup holders.
