Help choosinggear ratio
Old Dec 2, 2011 | 12:05 PM
69POLARA383's Avatar
Hey guys, need some input. Starting to rebuild my 9.25 rear end, looking for input...Rear wheels are 20", trans is 727 from a 69 polara ( not sure if that dictates gear ratio)
Thanks
Old Dec 2, 2011 | 12:33 PM
John Van's Avatar
What is it going into? Is the car just a cruiser or strip? How tall are the tires? Motor details? Convertor size? These all play into what gear ratio to use. Normally a 3.55 is a good compromise.
john
Old Dec 2, 2011 | 06:54 PM
john
'74 satellite, 528 stroker, tci ultimate streetfighter (4000+), 24" tire height, mostly street and some strip
Old Dec 2, 2011 | 06:58 PM
Okay remember that torque, weight and such are major players when someone is giving you advice on a torque convertor. I usually talk to a torque convertor builder and let him decide what I need. At that time he will also ask you what gear you are running. I would not go with 4000+ stall and 3:55 rear gears. My car will probably never see the strip and is lighter than yours. My 9 1/2" convertor stalls at 3200 and my rear is a 3:55. It runs in the 3000+ RPM range at 65 mph.
Either Paul with Turbo Action or Rick with A&A Transmissions
Old Dec 2, 2011 | 08:49 PM
John Van's Avatar
With such a small tire,go with a 3.21 gear. And like bremereric said, convertor is too loose,get a tighter convertor otherwise all the low end torque a 528 stroker makes is wasted. Why such a small tire? Looking for that low rider look?
Old Dec 3, 2011 | 07:24 AM
Too loose? So your saying my 800.00 converter is the wrong one? I was told that the stall had to be around 4000???
Old Dec 3, 2011 | 07:27 AM
Thats right about where I am at when going 65mph. Ill test it today and get back.
Old Dec 3, 2011 | 08:02 AM
John Van's Avatar
That depends on the cam and desired operating rpm range. What is the duration, overlap, and lift on the cam? Stroker big blocks don't need to rev very high to make power.
john
Old Dec 3, 2011 | 11:15 AM
4000 stall is going more towards race less for street. If you use that converter I would go with a 3.91 gear and a taller tire. It's too much converter
Old Dec 4, 2011 | 08:11 AM
john
http://www.summitracing.com/parts/CCA-21-671-4/
cam specs
What stall would you guys recommend?
Old Dec 4, 2011 | 11:02 AM
You have a 528, auto, 4000 stall, 24" rubber and your driving it now at 65mph turning about 3000rpm. If I have that right do you know or can you calculate the gear that is in it now. It sounds like a 3.55, I would stay with the 4000, change to a 3.9-4.1 with a solid pinion spacer but increase tire size.
Two things I see you have so much power you'll tear those tires off or wrap up the rear axle breaking U-joints or more. Sounds like your serious about your launch and I would recommend a rigid mechanical traction device and cup holders.
motasupra
Mar 15, 2015 12:01 PM
69POLARA383
Sep 24, 2010 11:29 PM
craveman
Apr 3, 2009 02:19 PM
318scamp
May 2, 2008 03:16 PM
318scamp
Apr 20, 2007 06:35 PM
