new trans needed
new trans needed
iam getting ready to get my 2001 dak V6 3.9 / 42 trans w/ O.E.M. cooler. with stock engine and exhaust. i know who will rebuild it. but i think i might want an over size oil pan. aluminium, steel? but not to tall, with a real drain plug. i looked on the internet and just got confused. ideas?
yep a deep pan is something ill look at. all so a temp gauge. elec or manual? and of course ATF +4 fluid ONLY. i have experimented with rear end grease in a 727 with good out come. but not now days. the dak has an O.E.M. trans oil cooler.
well i checked with mt trans shop. he answered my Qs to my liking. and the price will be $1,900. since i have known this guys since the late 60s i know ill be happy. so as soon as the gov sends me my tax refund ill be doing well.
but for low speeds my 4.1 gear does just fine. i drive only in town 30 MPH to 50 MPH. most of my cruse speed is 35-40. when i changed from a 3.55 to a 4.1 my MPG went from 8-9 to 11-12. cause the O.D. comes in at 35 MPH with lite throttle. and holds 1300 RPM at 30 MPH lite throttle.
From all my teachings and sources..... The best fuel mileage is obtained at 60 to 65 MPH With all the manufactures as designed. Period!
For what it's worth...
Not saying you didn't get it...... Just saying..
Ok..... How About a Turbo... Boost it Babe !!!!!!!
i didnt say i was getting the best MPG my TWK can get. its just that 99.999% of my driving is 30-50 MPH. today i found out that the IRS posted my refund to my checking acc. so it might get fixed next week. my trans guy didnt think an aluminum pan is needed. cause i have an O.E.M. cooler.
OK..Dont yell at me.... I'm Slow....
The dam Wind blows faster than you drive....Ok, I get it !!!!
Hope you get it fixed.
I'm just fun'in with you, I hope you know?
Ok... I got the fix !!!!!!!!!! I figured it out.... You got better gas mileage before 1965... Rite.... So after that you started getting worse mileage..... I got it.....
You started driving with both feet on both pedals at the same time... You are a 2 footed driver !!!!!!
my o my racer you make me reread what i post. the thing is i never checked my MPG till i got my 2001 dak. not that even care now. i check it in case something is not right. i do drive funny car style. but i dont drag the brakes.
Lots of rebuild videos on YouTube if you want to try it yourself. You do need access to a press for the Overdrive unit. 42 is the light duty A500 ? NOT a difficult project
just picked up the new trany. the main shift points are the same. and i think the new torque converter slips less. so it might get better MPG. now i need two new tires and front end alinement. then i want a coolant filter,
update it wont shift down to 1 st gear even at 12 MPH. i think ill take it back. it might be the control cable going to the TV. i know where the holder of the cable is. but i dont know how to unclip the cable. i hope my trans guy can show me. iam sure ill want to adjust it some more.
man o man i hope not. i was reading some pics and text.. i might be making it harder than it is. i might try to do it my self. years ago i modded the linkage on a 65 300 L. i changed the lever ratio to move the linkage less than stock. it turned out very good.
Rumblefish318
Jun 26, 2013 05:24 PM
Dodge Girl
Sep 13, 2012 09:16 PM
