shift kit
Old Dec 31, 2012 | 09:53 AM
Scott Moats's Avatar
shift kit
Hi All,Dumb question,do I need to be careful of anything installing a trans-go tf-2 shift kit with the trans upside down?Thanks much in advance,Scott
Old Dec 31, 2012 | 10:04 AM
I say you need to remove the valve body and do it outside the tranny because it requires you to drill out some holes.
Old Dec 31, 2012 | 06:33 PM
Gorts 5th's Avatar
Smile
there are bolts in the valve body that hold it to the case, and bolts that hold the two pieces of the valve body together.
you don't what to open the valve body up side down because there are small ball bearings that will fall out and you don't want that to happen.
you need a rebuild manual. that will help
Old Jan 8, 2013 | 03:10 PM
The shift kit comes with good instructions.. TAKE your time to follow them, take pictures if you are unsure how it goes together. Depending on your kit the seperator plate need to be changed or modified. Organize your parts And yes the valve body needs to be removed
scott2683
Apr 5, 2011 09:37 AM
1923tbucket
Jun 23, 2010 04:10 PM
Buffalojoe426
Apr 10, 2010 09:58 AM
71satellite
Jan 9, 2010 04:44 PM
printdoc
Jun 7, 2009 08:25 PM
