Speedometer problem
Speedometer problem
Hi all,
What causes a speedometer needle to bounce all over? That's what happens to mine. It will bounce up and down over and under my actual speed. Cable was new as was the gear for the tranny. Tried this on two different speedometers and get similar results.
Marty
Marty
Well...that sucks. Spent good money having the one cluster sent out to the states for refurbishing with specific mention of the speedometer needing to be checked. If that is the problem...then that was wasted money. However, the second cluster came out of a 76 Duster that had been on the road here locally and as far as I know it worked. But...it does not seem to now. Grrr....
I believe so...bit of a sharp twist that I managed to straighten out. That seems to have done the trick. Can only get up a bit of speed in the driveway. Will havce to wait for a proper road test.
Marty
Marty
