Speedometer problem
Old Apr 14, 2012 | 03:49 PM
Leem's Avatar
Speedometer problem
Hi all,
What causes a speedometer needle to bounce all over? That's what happens to mine. It will bounce up and down over and under my actual speed. Cable was new as was the gear for the tranny. Tried this on two different speedometers and get similar results.
Marty
Old Apr 14, 2012 | 06:23 PM
fivepoint's Avatar
Is there a sharp bend where the cable is routed? Disconnect the cable at the tranny and turn it by hand. It should turn pretty easy without any tight spots.
Old Apr 14, 2012 | 06:58 PM
Leem's Avatar
The cable turn ok.
Marty
Old Apr 14, 2012 | 07:14 PM
It's the old speedometer head in the cluster. Mine did it until I sent my cluster out for refurbish. Has something to due with the old white lithium grease.
Old Apr 14, 2012 | 07:59 PM
Leem's Avatar
Well...that sucks. Spent good money having the one cluster sent out to the states for refurbishing with specific mention of the speedometer needing to be checked. If that is the problem...then that was wasted money. However, the second cluster came out of a 76 Duster that had been on the road here locally and as far as I know it worked. But...it does not seem to now. Grrr....
Old Apr 14, 2012 | 09:58 PM
John Van's Avatar
Originally Posted by Leem
gear for the tranny
Marty
Why the new gear? did you use a different one? The housing for the speedometer gear has to be indexed to the number on the gear.
john
Old Apr 14, 2012 | 10:59 PM
Leem's Avatar
New gear and cable was put in when the car was converted to a 4 speed. It's the speedometer that is the problem...I think.
Marty
Old Apr 15, 2012 | 09:11 AM
mikerp76's Avatar
make sure that the cable is fully seated in to the back of the speedo. i had disconected mine and when i put it back together it was doing the same thing.
Old Apr 15, 2012 | 09:24 AM
Leem's Avatar
10-4
Going up to the garage to work on it now. Going to check the whole distance between speedo and trans.
Marty
Old Apr 15, 2012 | 02:25 PM
Leem's Avatar
I managed to get one of my speedometers to work. Problem resolved....I hope.
Marty
Old Apr 15, 2012 | 05:04 PM
Marty
Great was it the cable?
Old Apr 15, 2012 | 06:57 PM
Leem's Avatar
I believe so...bit of a sharp twist that I managed to straighten out. That seems to have done the trick. Can only get up a bit of speed in the driveway. Will havce to wait for a proper road test.
Marty
Old Apr 15, 2012 | 08:19 PM
Marty
Or you could smoke the tires down in the driveway and watch the speedometer.
Old Apr 15, 2012 | 10:41 PM
Leem's Avatar
No, not with my new tires...But...I think the kid will try that when he gets back in town...lol
Marty
stazja01
Nov 7, 2012 12:21 PM
DUCMAN166
Dec 21, 2008 07:49 AM
gotdust
Apr 27, 2008 10:31 PM
wheelman487
Apr 24, 2008 04:58 PM
wheelman487
Dec 4, 2007 07:49 PM
