Stainless steel transmission hose
Old Dec 20, 2014 | 04:40 PM
inri's Avatar
Is there a kit out that has prefabbed lines for a 727 to the radiator cooler? I've seen some online for other makes, but not for '69 B Body. I imagine (2) 7' or so lines with an fittings would do the trick. I'm tired of trying to run and then bed and kink the steel lines.
Something like this?
http://www.summitracing.com/parts/ad...PMVRoCKJvw_wcB
Old Dec 20, 2014 | 06:28 PM
moe7404's Avatar
dont for get to use anti-seize-compound on stainless steel threads. and i found an EXTERNAL filter.
use ONLY steel brake lines. copper WILL break off. the factory uses steel for a reason!!!! mopar most use 3/8 dia tube, but some might be 5/16. i think most have the fluid in at the rear left side. here is an EXTERANL filter, i found. have one on my 01 dak. my idea is when you put a new filter in side this one will help from having to do the inside one as often.*
the old auto zone 2210 magenfine filter is no longer available at auto zone. BUT i did find the same thing as JX-160 brand-- ATP. at a real parts house uses 3/8" tube. a JX-150 for 5/16 tube. ONLY use high pressure hose. If you must. SAE J1019 217 psi working. NOT fuel hose for a carb engine.
Old Dec 20, 2014 | 10:10 PM
Maybe Year One ??
https://www.yearone.com/Product/chrysler-b-body/qrb62
Don't forget all the little clips & holders
Old Dec 20, 2014 | 11:16 PM
inri's Avatar
Originally Posted by TVLynn
Maybe Year One ??
TVLynn,
These are the hoses that I'm trying to avoid, lol. I'm looking for a hose or stainless steel hose not a line, as I think the "line" is to firm and its hard to ru up and over and around in the engine compartment. Oftentimes, I kink them and ruin them. The hoses offer more flexibility to run to the cooler...
Has anyone run "Hoses" to a radiator cooler?
Old Dec 21, 2014 | 08:18 AM
I think XRP and Earls has about the best verity for what you are looking for....
http://www.xrp.com/wp-content/upload...ct-Catalog.pdf
99dakota440
Jun 11, 2012 07:55 AM
Mopar Nut
May 2, 2012 12:25 AM
crwchf16
Apr 23, 2012 02:25 PM
ottosen@chorus.net
Aug 12, 2011 10:14 AM
bremereric
Jul 15, 2011 02:54 PM
