stuck in park
Old Sep 25, 2012 | 06:31 AM
uglydukwling's Avatar
stuck in park
I have a '92 leBaron that has been parked for a while. The last time I tried to move it, it wouldn't come out of park. I disconnected the linkage, and the shaft that goes into the transmission won't turn. It appears to be frozen to the casting by corrosion.
For the last couple of months, I've been pouring penetrating oil on it every time I walk past, but it hasn't helped. I'm afraid to use a torch to heat it with so much plastic around to catch fire. I tried a hot air gun, but it wasn't hot enough to do any good. I also tried drilling a shallow hole in the casting against the shaft to serve as a reservoir for the penetrating oil. The oil disappears, so I hope it's finding its way down the shaft, but so far nothing moves.
Is there any chance that there's something broken internally, and the shaft isn't siezed after all? I kind of doubt it, since the shaft won't move at all and a broken part usually shows at least a small amount of play.
Any ideas to try before I take the transmission out and apart? I'm in no hurry, so if no one has any suggestions, I think I'll just continue with the penetrating oil for a few more months before I do anything drastic.
Old Sep 26, 2012 | 12:13 PM
MrOldart2U's Avatar
BFH? Well maybe not a Big one but a few taps may help it 'break' lose..
Old Sep 26, 2012 | 12:35 PM
Sounds like your ready for a rebuild or a good used tranny.
Old Oct 3, 2012 | 06:36 AM
I already tried pounding on it, but unfortunately (or maybe fortunately) there isn't room to get a good swing. If I end up having to take the transmission out, I can heat it, put a pipe wrench on the shaft, etc. If there's nothing wrong internally, I can probably fix it without taking it apart. I'm just naturally lazy, so I'm trying to do it without taking the transmission out of the car.
Old Oct 3, 2012 | 11:11 AM
I don't know where you are located, are you in a winter/ salt or other area subject to high corrosion? That shaft has a seal, there, so it should not be corroded. I'd guess a problem internally.
What is your "feel" for the condition of the transmission, that is had it been working fine when you parked it? If so, you can pull the valve body without removing the transmission.
sweeperking
Jun 3, 2010 05:21 PM
Crazy4Carz.Com
May 15, 2010 03:59 PM
rexus31
Mar 17, 2010 05:03 PM
CoogarXR
Jan 23, 2010 12:19 PM
flmopars
Dec 17, 2009 05:42 PM
