TF727 How to adjust the kickdown linkage?
Old Dec 8, 2013 | 01:40 PM
josehf34's Avatar
Hi I want to know how can I adjust the kickdown linkage on my Torqueflite 727 because when I get the throttle to the floor I can hear the carburetor secondaries opened and the transmission downshifts one time but I don't notice a big difference in the car acceleration so I think if I properly adjust the kickdown linkage the transmission will downshift two times and will be a difference in car acceleration
Old Dec 8, 2013 | 03:02 PM
bigblock's Avatar
What engine is in it? If a small block then it's adjusted correctly. If a big block then something else like spark timing or carb tune needs to be adjusted. None of them will down shift 2 times unless you are almost stopped. 5 mph or 10 maybe.
Old Dec 8, 2013 | 03:38 PM
josehf34's Avatar
My car has a small block 360. A few moments ago I try again on the highway and the transmission downshift one time but the response was a lot better.
Why the transmission doesnt downshift two times even goig at 25mph? If I want this kind of downshift must i shift it manually?
Old Dec 8, 2013 | 04:36 PM
You need to read the transmission diagnostics section in the shop manual In my '74 manual there's a chart on page 21-71 that shows approx shift up and shift down speeds. 1st gear downshift varies with engine, rear axle and body style, the chart shows all the way from 25 to 38 mph for a 3 to 1 downshift, depending
In addition, the throttle (kickdown) adjustment is in there as well.
Also, there is some service bulletins, both .pdf and video over at MyMopar that might be helpful............
http://www.mymopar.com/index.php?pid=451
Old Dec 8, 2013 | 07:18 PM
josehf34's Avatar
Thank you I'm going to look the diagnostics section, maybe I found some something that can help or confirm me that all is fine
Old Dec 8, 2013 | 09:11 PM
Do you have the proper factory service manual? 74 is it? paper? "on cd?"
Old Dec 9, 2013 | 10:35 AM
josehf34's Avatar
I bought this manual some days ago but It didnīt arrive yet. is this the correct manual?
Old Dec 9, 2013 | 05:57 PM
It appears to be. There were serious wiring changes in the car and in the diagrams in 74. Once you learn how to use the diagrams, it will be easier in some ways.
KJoeZ61
Sep 27, 2009 05:07 PM
Iskone
Jul 4, 2009 08:25 AM
nesparky
Jun 2, 2009 08:26 AM
DartConvertible
Mar 28, 2008 06:24 PM
button
Jan 26, 2008 05:30 PM
