Torqueflite 727 - Agressive shift and strange noise
Hi !
Today I get back my car from some brake work and I noticed some problems.
Due to poor engine performance I must shift from Drive to first gear if I want a decent performance but when I shift to second gear from first gear my transmission makes a noise like a blow and when it shifts it feels like a aggressive shifting not the soft shift.
I check the fluid level and is good but I have never change it.
What could be the problem?
Well without a year ,make or model. I can try to help...Why does it have poor engine performance??? Did it run poorly before the brakes were done???Why do you have to manually shift the car????It sounds like the shop where you had your brakes done took your car out for a test drive and put the hammer down and now the throttle valve ( on Transmission) is stuck in wide open throttle....Bill
Apparently the performance problems is due to the carburetor jet size, the car is running too rich. Before the brakes work the car had a better performance but I make the mistake of requested the mechanic to take a look to the carb and I think he try to tune up the carb and with this increased problems
How can I know if the throttle valve is stuck?
Where is located? I think I can take a picture of it and post it in the forum
Thank you!
The rod from the carb. to the transmission shhould have a spring on it to return it to the forward position. (assuming it is still hooked up) If it is not it will make it shift very harsh... But you need to get it running better first 360 s are good running engines as a rule....Bill
yes is a 2bbl Holley 2245.
I'm going to take some pictures of the kickdown linkage and post it in this topic
josehf34
This book would also be very helpful!
http://www.ebay.com/itm/Torqueflite-...83e#ht_8wt_679
josehf34
Today I noticed something. I think the my 727 Kickdown isn't working, If I push the throttle to the floor when I'm going at 40mph nothing happens, I dont feel the kickdown and the RPM doesn't change!
78PW400ci
05-03-2010 10:30 PM
sjparadiso
02-01-2010 03:36 PM
