tranny woes
Old Mar 17, 2014 | 12:41 PM
CdotEdot's Avatar
Smile tranny woes
Hi guys . Yes I,m a newbee. & I've got a transmission prob.
Well I bought a parts truck , just to get few small part I needed for my 85 W150 project. The parts trk is a 88 D100 long wheel base 2 Wd which had a bad rear end. The rest of the trk is in great shape. Too good for a parts trk. So I bought another parts trk (84 D 150) for my parts trk.
Well with that said When I went to get the D100 I started it for the first time in about a year & tried to pull onto my buddy"s trailer It wouldn't go because the rear was too bad. The trk would attempt to pull itself onto the trailer. It would spin or the rear would make rock crushing noises & slip. The tranny seemed fine. After getting it home via rollback it set for a week. When I went to pull it in the shop to swap rears The trans was slipping in forward gear. after I completed the rear swap it is still slipping. In drive it tries to move. in low it will move but slips when you accelerate once you get moving enough to shift into second everything works fine, up shifts, down shifts good until you get slow enough to go back into low than its slipping again.
Is there a quick fix or do I need a nother parts truck? Unsure what the tranny is at this time. It in not an over drive. 88 D100
Old Mar 17, 2014 | 01:38 PM
Make sure the throttle pressure linkage is hooked up to the carb !!
Old Mar 17, 2014 | 03:08 PM
If it slips in manual low and reverse the low/reverse band needs to be adjusted. Don't drive it until you do.
Old Mar 18, 2014 | 12:32 AM
CdotEdot's Avatar
Reverse is very strong no slippage
Old Mar 18, 2014 | 12:34 AM
CdotEdot's Avatar
OK I'll check.
Old Mar 19, 2014 | 01:08 AM
CdotEdot's Avatar
Angry
Originally Posted by CdotEdot
OK I'll check.
Well I pulled the pan. ITs toast! Lots of aluminium shavings.
Old Mar 19, 2014 | 02:49 AM
time for a rebuild and a new converter
Kurt
Mar 15, 2011 03:42 AM
tang72
Apr 13, 2010 11:26 PM
raindance654
Dec 14, 2009 09:41 AM
64fury
Jun 11, 2009 09:45 AM
rapidride2
Mar 20, 2007 05:58 PM
