Transmission fluid to use 727
Old Nov 1, 2014 | 06:24 PM
dgbcharger's Avatar
Hello Mopar maniac gearheads. Ok what fluid do I put in my 727 tranny. It had a soft rebuild performed on it 2 years ago. It shifted so smoothly but when I put the car on jack stands to restore the car in 2012, tranny fluid leaked out continueously from the pan gasket front edge. What fluid do I use to fill it back up: Type F, Dexron III, or ATF 4. I've read elsewhere ATF 4 (synthetic) makes the tranny leak. Don't know what's currently in it. It is red in color. It's a 72 Charger, 3 speed on the column. Help!! Thanks
Old Nov 1, 2014 | 07:31 PM
moe7404's Avatar
you might re tighten the pan. BUT the small screws go in to aluminum. limit torque to 10 ft lbs. if that does not work put a new gasket in. the gasket makers might have some new gasket that might better than the old ones. ill say to use ATF +4. but my experts here can help me here if i am off. and i found an EXTERNAL filter. use ONLY steel brake lines. copper WILL break off. the factory uses steel for a reason!!!! mopar most use 3/8 dia tube, but some might be 5/16. i think most have the fluid in at the rear left side. here is an EXTERANL filter, i found. have one on my 01 dak. my idea is when you put a new filter in side this one will help from having to do the inside one as often.*
the old auto zone 2210 magenfine filter is no longer available at auto zone. BUT i did find the same thing as JX-160 brand-- ATP. at a real parts house uses 3/8" tube. a JX-150 for 5/16 tube. ONLY use high pressure hose. If you must. SAE J1019 217 psi working. NOT fuel hose for a carb engine.
Old Nov 2, 2014 | 02:40 PM
Mr.4spd's Avatar
Type F. It has friction modifiers and will help the trans shift firmer and quicker, but if that is a non-issue Moe's advice is solid.
Old Nov 17, 2014 | 03:32 PM
Gorts 5th's Avatar
Smile
Type f make .....sure it has the chrysler / mopar logo/ recomended on the pakage
Old Nov 17, 2014 | 07:40 PM
Mr.4spd's Avatar
It probably won't, it's specified for Fords. Works just like B&M Trick Shift for a fraction of the cost.
Old Nov 17, 2014 | 07:49 PM
moparted's Avatar
fix the leak first
Old Nov 18, 2014 | 02:27 PM
DLJ's Avatar
DLJ
Mopar automatic transmission fluid for torqueflite
I think type F would be the fluid most mopar people like on old torqueflites.
Once I am doing some work on my old 1976 A-904-LA after a long 15 years garage sleep, I found some quite interesting information on youtube.
Some Chrysler videos from the 70's would recommend to use only Mopar approved DEXRON type fluid and state do not use type F under any circumstances
Now Mopar recommends only ATF+4 for any torqueflite.
I am not a tranny guy but I think much depends on parts in your tranny. In my case all clutches, seals and bands are stock from 1976 so I am using DEXRON II which is available and cheap in my area, I hope it works fine on my old frictions because the tranny was working and shifting just fine before I decided to fix the pan leack, clean up the pan and VB and install a Trango TFSC shift improvement kit, new filter and shaft seals.
Old Nov 19, 2014 | 01:34 PM
I would get the MP performance deep pan and pickup. also the later 518 hard plastic gasket
http://www.ebay.com/itm/46RE-47RE-48...f699be&vxp=mtr
If the pan flange is warped it will never seal...
jonnyb
Nov 5, 2013 02:50 AM
Kowalenko93
Oct 4, 2013 05:38 PM
Gorts 5th
Oct 30, 2012 03:44 PM
jimiheadstone
Aug 9, 2012 12:59 AM
elsmootho
Aug 17, 2010 03:18 AM
