Transmission slip
Old May 17, 2016 | 06:29 PM
raycan2's Avatar
Transmission slip
So I have a 727 torque flight transmission. The car is running good but the issue I am having is as I'm driving or taking off from the stop light it seems like it does not want to shift till it gets up into a higher RPM, then all of a sudden it'll shift into overdrive and it sounds like a little clunk...or when I start off on 1st I can change to2nd and it takes a while for it to shift, the same thing when I shift into Drive from 2nd I have to really get on it some then all of a sudden it almost like it clunks and catches fine, now it was not doing that before,,,Any thoughts?
The other thing it seams like I can flore the gas pedal all the way down and it feels like iam 1/2 ways their as far as power.
Old May 17, 2016 | 07:17 PM
You do have the T.V. hooked up adjusted properly?
Old May 17, 2016 | 07:40 PM
raycan2's Avatar
O.k. Racer excuse my ignores,,, but what do you mean by T.V. ???? I am new to this and iam learning as I go....
Old May 18, 2016 | 06:41 AM
The Transmission has a linkage tying the carb to the trans mission. Throttle Valve Pressure is what it controls... If the linkage is missing. The trans line pressure is to low and causes the clutch's inside the transmission to burn up. also when miss adjusted, it will cause ill-rattic shifter patterns.
There are was around it, but it call for replacement of the transmission valve body...
This is just the short and sweet version....
Old May 18, 2016 | 06:44 AM
raycan2's Avatar
Oh yea, I think you sent me a You Tube video on that and it is in place, as a matter of fact just yesterday I had to losses up the headers to put on the clip that hold the link arm on so it would not fall off, but that is a possibility i need to check that today.
Old May 18, 2016 | 05:40 PM
raycan2's Avatar
Darn thing has me so frustrated now, I have tried everything that I know of and it still doing the same thing, iam just to stubborn to take it to a machanic because I am determined to learn how to do or fix it.
Old May 18, 2016 | 05:45 PM
You did check the fluid level in Neutral and at idle?
Old May 18, 2016 | 05:52 PM
The lever does move freely rite and linkage?
Old May 18, 2016 | 08:36 PM
raycan2's Avatar
So I checked the fluid level...GOOD... Lever is good but a little stiff, I hopping that's it but every thing else checks out.
Old May 19, 2016 | 03:39 PM
Well If that all hooded up and fluid is good..... Sounds like is going to need a trip to the trans shop.... Ouch...
Old May 19, 2016 | 06:14 PM
raycan2's Avatar
Don't say that!!!! Iam still messing with it,,,maybe I need to make a trip to your shop and drop it off...
Old May 19, 2016 | 06:26 PM
Just stop at the "Welcome Race Fans" sign and say.... Is Cowboy Bob here !!!!!!
Will Get-R-Done.....
Old May 19, 2016 | 06:32 PM
raycan2's Avatar
I wish I could take a drive, it's pretty far I am guessing..
Old May 19, 2016 | 06:44 PM
My Niese lives down near Cheyenne... I could swing by.....lol
Ok.... Get it freed up.... Make sure the linkage moves freely... In the relaxed position. the slotted part of the linkage at the carb. Should be slid forward almost touching the stud. Without the spring hooked up to pull it froward.
Old May 22, 2016 | 10:22 PM
The lever for the kick down on the trans should move freely NO binding. You may have to remove the pan to check it... The valve it operates could be stuck / bent????
Old May 26, 2016 | 08:03 PM
moparted's Avatar
overdrive?
Old May 27, 2016 | 06:27 AM
Originally Posted by moparted
overdrive?
Oh Stop.. Your such a smart azz at time's....
Old May 27, 2016 | 06:51 AM
raycan2's Avatar
Yea my father law said the same thing, its hard to tell with the headers in, I can not get my hands in to check, everything is so tight..I might have to take the headers off again or losses them up.
ZombiePopper
Mar 30, 2020 05:58 AM
Boompy
Mar 24, 2016 07:12 PM
pro-tech
24
Sep 3, 2013 08:08 AM
75Duster360
Aug 11, 2013 07:58 PM
snaponbob
Oct 17, 2012 04:34 PM
