what trans speedo gear do i need?
Old 01-31-2013 | 03:07 AM
maca's Avatar
Hi all
I am using a online tyre calculator to work out my tyre size. I have tried 3 and all three keep changing my tyre size from 245 to 225. Maybe they are the same. Not sure.
My tyres are 245/60/14
It says on the calculator that it is 650mm which equals 25-5 inches.
My diff gears are 3-45
If the tyre calculator is correct (can anyone check please) I should be running a number 36 gear?
Cheers maca
Old 01-31-2013 | 06:26 AM
Gorts 5th's Avatar
Smile
sound's about right i have a 3.90 gear and i'm using a 39 tooth gear.
check here for assistance...
http://www.transmissioncenter.net/dodge.htm
wait till you see all the trany parts here.
you may need some parts here for the retro...
speedo cable
your doing the 518 swap right? that was a great video you posted i watched them all it sure made allot more sense that when i first did it all i had was the manual no vid.
74Runneer
12-07-2013 03:16 PM
AV8AP6
04-01-2012 05:19 PM
Cazbah362
03-19-2012 04:52 PM
mayflower1
08-01-2010 09:51 AM
65AzBel
02-10-2009 02:30 AM
