aftermarket brake pedal assembly
Old Sep 4, 2013 | 12:04 AM
383mopar's Avatar
Does anyone know of any aftermarket brake pedal assemblies that have a shorter gap to the floor than the stock brake assembly? I have limited mobility in my ankle, that's why i'm asking.
Old Sep 4, 2013 | 11:28 AM
DO you have power brakes ? Pwr pedel is much closer to the floor than manual brakes
Old Sep 4, 2013 | 01:02 PM
You could go to Hand-Control, If it's a handicap issue....
http://www.mcmobilitysystems.com/Mob...ls.aspx?ID=128
Respectfully
Bob Hogan
Old Sep 6, 2013 | 12:02 AM
383mopar's Avatar
power brakes are a good idea but i have to figure out how that system would work with a tunnel ram. as far as hand controls go, my problem is not as severe to have to resort to that. i have driven other vehicles before, but i would like to feel more comfortable in my mopar.
Old Sep 6, 2013 | 05:33 AM
Easy enough..... Cut the pedal and reweld a braket to set the pedal where you like it..... And your done and ready to ripp it up again...
Old Sep 6, 2013 | 12:06 PM
No vacuum with a tunnel ram. SO for power brakes you would need some type of electric vacuum pump.
IF that is not low enough YOU need the hand controls !!!
I would not cut the peddle. If any type of accident happened ? could have big problems
Old Sep 6, 2013 | 12:12 PM
Just remember...You will have limited travel....
Oupps..Almost my bad...
cudagecko
Apr 20, 2013 08:24 PM
cudagecko
Apr 19, 2013 02:54 PM
Daviddzur
Feb 16, 2012 09:22 PM
tcherrone
Apr 15, 2011 05:03 AM
1966DartConvertible
Sep 21, 2010 06:28 PM
