Brake Drums Needed
Old 12-03-2012 | 09:43 AM
Larrycuda's Avatar
Brake Drums Needed
Hey All.
I am having a heck of a time finding some 10 inch x 1 3/4 inch drums for a 1965 Barracuda. I've tried about 15 places here in GA, a few in AL, and am stuck...looking for help.
Any advice or points in the right direction would be greatly appreciated.
1965 Plymouth Barracuda
V-8 273
Discs on the front, drums on the rear
If I've missed anything that would be beneficial to you, let me know and I'll post it.
Thanks
Old 12-03-2012 | 11:52 AM
I saw a listing for 10 X 2 are you sure of the size ?
Old 12-03-2012 | 12:29 PM
Larrycuda's Avatar
I'm 99% sure. I took the pads off and matched them that way for the new pads. I had the old ones turned but they were too thin to use. The surface area that was turned is a hair under two inches when measured, but the pads that came off are 1 3/4".
If it makes any difference, it is a late series '65 when they started beefing things up and went from 9" to 10". It has that "S" on the front fenders.
https://docs.google.com/open?id=0B1S...GltYm5ycmNJQzg
Old 12-03-2012 | 02:31 PM
A 10"x2" drum may fit? Have you tried one ? shoes are generally slightly shorter in width than the drum. Usually the drum has the size cast into it..
Are you sure it is not a 9" drum I had a 65 back in the early 70's non S As I remember it had crappy 9" drums
Old 12-03-2012 | 03:22 PM
Larrycuda's Avatar
I have not tried the 10x2 yet. I had a place pull a 10x2.5 and it was no where near. I'll try that though.
Here is a link to the drum: https://docs.google.com/open?id=0B1S...HVzYVY5NUlZWG8
And here is a link to (what I believe is the correct part number):
http://shop.advanceautoparts.com/web...ntent=10711125
It's just finding them that's proving to be a challenge.
Old 12-03-2012 | 04:52 PM
I would go and get a complete set up from a later A body with the 9X2" setup if you still have the 4" bolt pattern. Make life easier..
Old 12-06-2012 | 08:51 PM
mikerp76's Avatar
auto zone shows a set for a 66 that is 10X1.81" part number is 151
jimiheadstone
11-02-2013 08:02 AM
willysman69
03-15-2012 10:27 PM
KJoeZ61
07-24-2011 10:59 PM
Commando
04-22-2009 07:17 PM
unruler
02-03-2009 03:00 PM
