Brake Drums Needed
Old Dec 3, 2012 | 08:43 AM
Larrycuda's Avatar
Brake Drums Needed
Hey All.
I am having a heck of a time finding some 10 inch x 1 3/4 inch drums for a 1965 Barracuda. I've tried about 15 places here in GA, a few in AL, and am stuck...looking for help.
Any advice or points in the right direction would be greatly appreciated.
1965 Plymouth Barracuda
V-8 273
Discs on the front, drums on the rear
If I've missed anything that would be beneficial to you, let me know and I'll post it.
Thanks
Old Dec 3, 2012 | 10:52 AM
I saw a listing for 10 X 2 are you sure of the size ?
Old Dec 3, 2012 | 11:29 AM
Larrycuda's Avatar
I'm 99% sure. I took the pads off and matched them that way for the new pads. I had the old ones turned but they were too thin to use. The surface area that was turned is a hair under two inches when measured, but the pads that came off are 1 3/4".
If it makes any difference, it is a late series '65 when they started beefing things up and went from 9" to 10". It has that "S" on the front fenders.
https://docs.google.com/open?id=0B1S...GltYm5ycmNJQzg
Old Dec 3, 2012 | 01:31 PM
A 10"x2" drum may fit? Have you tried one ? shoes are generally slightly shorter in width than the drum. Usually the drum has the size cast into it..
Are you sure it is not a 9" drum I had a 65 back in the early 70's non S As I remember it had crappy 9" drums
Old Dec 3, 2012 | 02:22 PM
Larrycuda's Avatar
I have not tried the 10x2 yet. I had a place pull a 10x2.5 and it was no where near. I'll try that though.
Here is a link to the drum: https://docs.google.com/open?id=0B1S...HVzYVY5NUlZWG8
And here is a link to (what I believe is the correct part number):
http://shop.advanceautoparts.com/web...ntent=10711125
It's just finding them that's proving to be a challenge.
Old Dec 3, 2012 | 03:52 PM
I would go and get a complete set up from a later A body with the 9X2" setup if you still have the 4" bolt pattern. Make life easier..
Old Dec 6, 2012 | 07:51 PM
mikerp76's Avatar
auto zone shows a set for a 66 that is 10X1.81" part number is 151
jimiheadstone
Nov 2, 2013 07:02 AM
willysman69
Mar 15, 2012 09:27 PM
KJoeZ61
Jul 24, 2011 09:59 PM
Commando
Apr 22, 2009 06:17 PM
unruler
Feb 3, 2009 02:00 PM
