Brake Master Cylinder Push Rod
Anybody know where I can get the correct brake master cylinder push rod that goes to the brake pedal for a 72 Cuda with a manual transmission and manual brakes? I converted from an automatic transmission and the push rod is too short.
So start checking the junkyards... An A body would probably be easier to find with manual brakes... Still sounds strange As I remember the Power Brake pedal linkage is attached to the booster ??
Pedal height will change from power to manual
