Camber degree 1959 Chrysler?
Old Nov 17, 2024 | 09:57 AM
Andersjohansson84's Avatar
Anyone know what degrees of camber should be on the 1959 Chrysler? (negative/positive)I have changed the upper bushings so want to adjust it.
Old Nov 18, 2024 | 09:24 AM
Mopar wheel alignment settings
When using modern radial tires on the rear wheel drive ’50/’60/’70’s Mopars, front wheel alignment can/should/needs to be adjusted for more and better steering response and overal safer handling of the car.
The following chart shows alignment specification values for various driving styles which can/should be provided to the alignment shop.
Driving style Camber Caster Toe-in Sunday Cruising -0.25° +1.5° 1/16" to 1/8" Daily Driver / Street -0.5° +2.5° 1/16" to 1/8"
-0.5* Camber
Old Oct 26, 2025 | 12:39 PM
sallyrenme01's Avatar
Can someone explain caster? That one is still a little weird
snaptube vidmate
Old Oct 26, 2025 | 12:54 PM
xaza's Avatar
https://suspensionsecrets.co.uk/caster/
tcehjes
Jan 31, 2017 11:02 AM
moe7404
Jan 13, 2014 08:46 PM
moe7404
Aug 16, 2013 06:23 PM
Moparknighthawk
Jun 5, 2009 06:42 AM
trucker ed
Mar 8, 2008 07:21 PM
