coil spring sag ?
Old Jul 5, 2012 | 08:22 AM
michuy's Avatar
coil spring sag ?
i've got a question about coil spring sag. ok, the coil springs on my 20-someting year old d100 2wd truck aren't broken, cut, or anything like that, but the frontend is now almost 4" lower than the rear (measured at the fender wall), i've already broken the plastic headlight adjusting screw retainers at least once or twice trying to get the headlights to illuminate more than a couple of feet in front of me. anotherwords the frontend it's really sagging. i'd also like to lift the frontend just enough to give it that 'level' 4x4 look. so my question is how much do coil springs generally settle over the years with normal use? just trying to figure out whether to order some custom springs with a 1.5", or 2"-2.5" over stock free height, in order to get me that level stance without over doing it. i do know that 2.5" is about the max lift you can make to the stock frontend without compromising the geometery and having to make other more expensive changes. also, how much of a factor would worn-out shocks be?
Old Jul 9, 2012 | 09:37 AM
Gorts 5th's Avatar
you should go with oem style replacements simpler worn out shocks dont really affect your ride height just the damping effect on suspension travel of course worn shocks will make your front end behave in an uneven manner check out adco suspension on the internet they have a lot of options
Old Jul 9, 2012 | 12:23 PM
You might spec out something for a D200 Go to a 3/4 T spring
Old Jul 9, 2012 | 03:47 PM
Silverick's Avatar
Personally, I would look at the availability of coil springs to gain your lift.
Find a good suspension manufacturer that specializes in lifted trucks and they will also know what else that you may have to change in order to get your lift and have the truck drive good.
I have a lowered Chebby pick-up with all Belltech lowering stuff, including front 'lowering' coils and everything works together....
Old Jul 9, 2012 | 03:52 PM
You can also get those knuckles at an auto parts store that put in the coils to gain more lift. That's the cheapo way.
celt69
Jun 19, 2015 11:45 AM
owenmachine
Feb 5, 2011 02:49 PM
sgp7679
Jan 11, 2009 11:52 AM
stazja01
Nov 17, 2008 04:24 AM
kidcoolbreeze
May 28, 2007 01:35 PM
