Dam it, can't get upper bushings out of E body
Old Oct 3, 2011 | 07:26 PM
cudaracer's Avatar
I have one single rusted on bushing keeping me from completing my front end rebuild.
Any ideas?
Beating it don't work.
Blue tip wrench so far has burned off the rubber and I even chiseled the outer shell of bushing, exposing only inner. Vice grip not working.
Ideas?
Old Oct 3, 2011 | 07:55 PM
Take a hacksaw and pass the blade through the center, saw the inner sleeve trying not to touch the arm. This will relieve the press fit pressure and should knock out easy.
Old Oct 3, 2011 | 08:06 PM
cudaracer's Avatar
Pass it through the center?
The axis of the bolt is horizontal. I am thinking of a blade to the left and right of the frozen bushing, but not the center. Can't run a blade axially along the bushing either, of course, as there is no room.
Old Oct 3, 2011 | 09:10 PM
mikerp76's Avatar
air hammer. and some pb blaster works wonders.
Old Oct 4, 2011 | 11:57 AM
JS23's Avatar
Is this an upper control arm bushing?
I use a dremel and score a vertical channel down the inside bore.
I've heard you can weld a large washer to the bushing shell and then press it out. However dont inadvertently weld the shell to the arm.
Old Oct 4, 2011 | 12:11 PM
JS23's Avatar
Old Oct 4, 2011 | 06:08 PM
Remove the upper control arm from the car, drill or burn out all of the rubber with a torch. Then remove the bushing sleeve as suggested depending on tools available. Don't try and hammer in the new bushing, pressing in or pulling with threaded rod and washers will not damage the new part.
If the rusted on part is the mounting bolt you may have to cut the bolt and purchase new bolt, nut and eccentric washers.
Old Oct 5, 2011 | 05:41 PM
scotts74birds's Avatar
Chances are, due to age, you probably should remove the upper control arm, and rebuild it anyway.
Old Oct 5, 2011 | 06:30 PM
Done it on two cars with an air hammer..as before mentioned I used 3/8" all-thread with some washers and nuts to pull two of them in at a time.
JETBLU
Aug 17, 2013 05:50 PM
fluffoffal
Oct 10, 2012 06:03 AM
chezhed
Aug 8, 2011 07:09 PM
nater
Jun 2, 2010 02:48 AM
upnorth52
Oct 23, 2008 09:07 PM
